Gleise/Weichen
Gleise
Weichen
6 -> Lead 48'
6½ -> Lead 53'-3¼"
8 -> Lead 60'-1¾"
9 -> Lead 73'-7½"
10 -> Lead 80'-6"
12 -> Lead 97'
14 -> Lead 109'-3¼"
16 -> Lead 131'
20 -> Lead 149'-9½"
6 = 10mph = industry tracks
6½ = 10mph = industry tracks
8 = 15mph = yards
9 = 15mph = yards
10 = 20mph = yards
16 = 30mph = passing tracks
Herzstücke
Antriebe
•Handantrieb
•mechanischer Antrieb
•elektrischer Antrieb
Kreuzungen
-einzelne Bauteile, welche zwischen die Schienen profile geschraubt sind
